karl h
ok so now the seat only works when it wants to, is the pressure regulating valve that is under the steps serviceable? Case wants 500.00 for the valve and there is a seal kit available, but I am thinking that the spring inside is shot? Anyone had this valve apart?
take that valve apart and clean it really well, what you likely have is a small piece of dirt/debris floating around inside it somewhere that causes the valve to stick from time to time, mine went through that for about 3 months before it finally cleared itself and now its back to working as it should.
While we are on the subject, what causes the seat to leak down overnight? Comes right back to the set position about 15 seconds after the tractor is started.
