Case SC clutch
dslfarmer
I have an SC case that has been sitting for a while. I got it started and the clutch wont stop. It has the hand clutch but wont release. Anyone know something about this? Thanks
clutch plate is rusted to the flywheel. You need to remove the side covers and try to break the clutch plate loose.
Might spray some diesel fuel in there to help loosen it up. I guess you know that there is a drain plug on the bottom of the bell housing to get rid of the diesel fuel. It is a common problem. I don't engage the clutch on mine, if they are going to sit for a while.
