rear plow axel jta plow
i am in need of a rear axel for a jta plow. it is part number t28065 which is replaced by t52969. mine was broke between the bearings in the rear wheel hub and i doubt welding it would hold. if you have one let me know.
thanks
gramps
very nice job! Where did you get the spindle from? Is it the same as the case one as far as bearings and using the same hub?
thanks
gramps
That spindle came from the amish country store down the road it is much, much sturdier, I would say 3 thousand pound or heavier. My JT has a six bolt wheel and bolted right up. The tubing was heavy wall we had to machine it out a wee bit. And no the OE bearings are much smaller. Tom
