case 311b belt pulley
cookster
What for bolt goes in the bottom left corner of the belt pulley casting to bolt it on tractor? I had the unit off and found the bolt to fit it but when I put the unit on the bolt wont go through casting. Just wondering if it is a special bolt?
My 200b parts book lists 4, 5/8ths X 11/2 bolts. That would be four five eighths by inch and a half long bolts with no part no. You may have to look in the hole and see if it was threaded deep enough. Maybe that hole was done on Friday end of shift and not quite deep enough.
The bolt threads into the tractor with pulley unit off but it wont go through the hole in pulley unit to bolt it on.
I agree with BarryfromIA
