joystick for 2096
timbernt
I am still looking to find a neat way to put a joystick on my 2096. I would like to put the stick just to the right of the 3-point control lever, but that won't allow a place to run the control cables since they can't be bent that sharp. What about the electric control joysticks? It should be fairly easy to mount just to the right of the console and I should be able run the wires down thru the console using some type of flexible conduit. But, does anyone have the experience to tell me if it will work and where to source parts?
I also have a question about adding a joystick for a loader on a 2096.My loader now is connected to the rear remotes.I want to add a joystick to free up the rear remotes.Where can I tie in to the hydraulic system for both pressure and return?
