information for a 1942 Case
medicn2u2
New User
I just purchased a 1942 Case Tractor and it has a single front wheel, a three point hitch with PTO. I am looking to find more information about it as I have the original title but it does not tell me the model as I have not been able to go over it with a fine tooth comb yet. I am also looking to get information on any implements you might now of that will go on this case. Here is a pic to help out.
Thanks
Tim
It is a Case SC with a dual-fuel setup. Also, how do you know it is a 1942? The air filter looks like a 1941, though the rear wheel centers are from later. Additionally, the colors are not quite what the factory intended.
Also, from what I can see, it has the lifting bail system. This is not really a 3-point hitch, but it can be made to work with 3-point implements with some fabrication work. However, on a pre-1947 model SC, the lift is purely mechanical. This means that it will have only a fully up and fully down position.
Hello Chris, I was basing the 1942 off of the title but I was told it was a 41. I just picked this tractor up on the 15th and the guy did prove that he gave it a new paint job, new rubber all around, new hoses, and wires. I need to put a new battery and clean the gas and it should start right up.
Needs a top on the air cleaner pipe before it rains. Wonder why someone would spend the time and money to paint it and not put the factory paint colors on it. Where is it at that you get a title for a tractor??? Don't have any for mine.
It is an SC-3.
I could be a late 42. I've seen 42's with the lights on the fuel tank support. The hood does not have the chrome strips nor does it look like it has holes punched for the chrome.
If it had the missing fenders it would be easier to tell the year.
The lift is not a 3pt. It is a mechcanical lift runs off the PTO. it has two settings. Up or down.
