Crossmotor case
Hello, I'm looking for some 18-32 parts. Need a couple of good cylinder liners if not all four. Also looking for the right rear wheel center cover. Any help would be appreciated.
(quoted from post at 16:20:48 10/18/14) Hello, I'm looking for some 18-32 parts. Need a couple of good cylinder liners if not all four. Also looking for the right rear wheel center cover. Any help would be appreciated.
I had a similar problem. I got a NOS set with my tractor but being cast iron I doubt they will last long so my original rusty ones are getting bored out and dry sleeved and I'm using a Waukesha piston, same compression height and wrist pin diameter just slightly larger bore and you need to clearance the rod opening in the piston a little.
