Case header wagon...pics
casecollectorsc
Location
E central SD.
Waiting for the corn to get drier to combine.
Decided to build a header wagon for the JD 220
flex head. Had a Case running gear looking for a
job. Guess you could say Case is supporting JD....
can't bring myself to actually type the words.
Looks good Steve, I could use one also. However I am lacking a Case running gear. I can down grade and use a Minnesota gear that is not good for anything else, LOL. Rod.
I'll bet a Minnesota would work just fine. Had everything I needed in the iron pile here. Could use smaller tires on the left side but found out used 14" tires are scarce as hens teeth.
