Farmer Jack
putting the differential back in a 1949 VAC. Was careful to keep the RH and LH parts separated. new cones and cups were used matching the timpken numbers. I heated the cones in a saucepan of oil and dropped them on and used the old cups to tap in the new (using as drivers). I looked at everything and it seemed all was seated properly. I tried sticking a feeler gage under all the parts and it wouldn't go in. However, I added to shims to the RH assembly and several to the LH assembly. I can just barely turn it by hand and the nuts are about flush with the studs on the LH assembly. I don't have the clearance I should have in the spider gears and there is no backlash in the ring and pinion gears. I replaced all the bearings in the transmission itself and that went together just fine. I followed the Case VAC service manual during the rebuild.
Any ideas on how to get the clearances back in the differential? Any pointer on what to look for in what I might have missed?
Also might need some more shims. trying to put this together for my son before its too cold to work on it.
thanks,
thanks,
