930 cab fit on a 941?
Well the 941 you are refering to is a rowcrop LP or gas fueled tractor. If you have a diesel, it would be a 931 row crop. or a 932 "Western" The 32s usually had the wide fenders, but not all of them did. If the cab you are refering to was on an LP tractor the cab fill plate on the rear of the cab sealing it to the Lp tank will be different, but that is an easy fix. Is the cab you are refering to, a factory cab or an aftermarket cab.
Loren
I read your post too quickly, and apparently you own the 941. As I stated, the only issue would be the fill plate if you have an LP tractor. Straight gas will be the same as all 931/2 diesels.
Loren
