joystick for 2096
timbernt
I got the tie rods fixed and put my TA-46 loader on the 2096; it is a really nice fit. My next project is to put a joystick on the 2096. Does anyone have a suggestion about placement on the console and where to find parts?
(quoted from post at 20:04:40 10/09/14) I got the tie rods fixed and put my TA-46 loader on the 2096; it is a really nice fit. My next project is to put a joystick on the 2096. Does anyone have a suggestion about placement on the console and where to find parts?
he one I had mounted on a square tube pedestal,from the floor,in front of the console,you have to drill a hole big enough to bring the cables through,then bolt pedestal to floor.might still have it around here i'll look.
Got a complete aftermarket assembly from Elmers Repair. Wish I had spent a couple hundred more and gotten OEM. The little square clamp the bolt goes thru was made of pot metal and both broke as soon as I tightened the bolts. No way to adjust it so the tractor doesn't turn shorter one way than the other. The whole assembly is much weaker. The flange the steering cylinder attaches to is just a piece of flat plate with a really weak weld to the tie rod. All in all it is a POS. Will undoubtedly break at an inopportune time.
