1030 oil pressure sender
toolz
I'm cleaning things up on this old 1030 I just bought- lots of screwed up wiring and bad gauges. I'm changing to a mechanical temp gauge, and installing a mechanical oil pressure gauge to replace the idiot light. Where is the oil sender? Can't seem to locate it. I need a place to hook up the pressure line.
May be other pipe plugs in that oil vein on the right side of the block, it is the same one that lubes the injector pump.
