Case 400 Tie Rod assemblies
Guzzy64
New User
I am trying to replace old tie rod assemblies the previous owner(s) put on my 1955 400 diesel that are different. Looks like these are hard to find. Anyone have any ideas where to find or is the same used on another model? Thanks for any help in advance.
The early style tie rod ends are not available as far as I could tell when I needed to replace the ones on my early 401 which had the same front axle as in your pic. I ended up having to find some ends that were the right size, and welding them on. Not something I recommend, but.....
FYI,
I contacted John Saeli and he was able to help out.
I was able to get both inner and outer tie rod and sleeves. I did have to remove plate underneath and have reamed slightly larger. I believe a friend of mine told me about 2 1/2 degrees.
Glad you were able to find something that will work. Nice looking paint. I hope to get my 400 painted this winter or next spring.
Eli
