sloppy steering in the field on CC Case
If you pull in and out on the steering wheel, does it have much play? A loose or bad bearing on the bottom end of the steering shaft could cause that much play in the steering wheel. The other trick is to remove the steering arm from the steering box and rotate the steering wheel so that the shaft goes 180 deg., and then stick the arm back on. This will expose new gear surface to the steering worm, but it is also possible that this has already been done once.
