On the right hand side of the 504 motor (looking from back)there is a frost plug type of plug 3 1/2 to 4" in size, it would lead to the "back side" of timing gears. (Hope I explained it right)
If the plug was removed and the block drilled and tapped, any reason a orbit motor could be installed to run a air fan on small air drill.
The reason I ask is I did it on my 855 Versatile instead of atom jet kit and it works perfect.
BTW tractor has NO pto.
TIA
TIA
