470 injector leak
mcg
I have a 1972 diesel 470. One injector is leaking where it enters the engine. I looked at Case's parts diagram, and it shows a washer and a seal there. I'd like to pull the injector out, and replace the seal and washer. I haven't done a lot of work on diesel engines, so I'm wondering if I'll run into a lot of problems, or if it will be fairly simple. I'm not sure the seal or washer is bad, but that's where the leak seems to be, so I figure I'll start there.
No problems getting it out, or back in. Washer was broken, but also had a pin hole in the injector, right under the washer. Waiting on a new injector
