Eagle hitch
Posted a few times before about our 730 with eagle hitch. Now my boy would like to make it his snow mover. Question is what would we have to do to make a three point blade work on an eagle hitch?
If you have the casting that goes over the pto it will go right on. You can hook the 3rd arm to the spot above the hyd pump but you Will need to extend the third arm hookup on the blade to match.
You need to either find or fabricate a top link mount that goes over the PTO shaft. You may also have to raise the top link mount on the blade by 6" or so. Even then the geometry is different and it won't lift near as high as a standard 3 pt. If you lengthen the lift arms by a foot it will be near a standard 3 pt for lift.
