1070 leaking remote valve
My 1070 is leaking oil from the remote valve at the bottom where the levers go up into the box. looks like possibly a shaft going up through a shaft. Can anyone give me an idea what this involves?
CASE puts together a kit to fix that. It's not too bad a job. The 4 bolt cover comes off the back, loosen the small forks on the vertical shafts & pull the shafts out & re-seal. We keep a kit in stock.
John on a 1070 the valve body has to be removed from the tractor to replace the orings in the levers. With the body on the tractor there is not enough room to remove the levers. Rod.
is removing the valve body straight forward ??? remove lines and exterior bolts, etc. Thanks for your help.. any part number for that kit, I don't think my parts man is familiar??
Valve is easy except for the two bolts at the top that com in from the front. You will probably swear
