Still Looking for 830 Case-o-Matic Part
Bobl1958
I am still looking for a GOOD USED or NOS high pressure valve assembly that goes on the Case-a-matic pump in a 1964 830lp tractor. I believe either valve assembly will work, either the A23008 or the A20729. One is for the newer tractors, but it looks like they supersede each other. Thanks for any help you can give. Case/IH no longer has them. Bob
There ia nothing "high pressure" about a COM tranny. The relief valve screws into the pump. Any tractor salvage yard that has a COM tractor should be able to provide you with a relief valve for about 20 bucks.
Loren.
