Case 377 rods
The pin size is my only uncertainty but someone has that info, the rod journal is 2.750 and the center to center length is 10.5" that should be the same specs as all Case rods including the small crank 504s. The wrist pins size increased as the HP increased.
I believe the latest pins were 1.625.
Big crank engines use a 10" rod with a 3" journal and 1.800 WP size
Yes, I know the later pins were larger, thats why I said the later pins, If you are considering swapping parts around I wanted to let you know the possibilities. I adapted a set of 4 5/8 Minnie pistons to 730 rods by sizing the 730 WP bushing to accept a MM bushing pressed in and sized for a 1 1/4" pin.
