2390 stuck in Reverse
John Holman
New User
My father in-law has a 2390 that is stuck in reverse. Not the linkage, but it moves backwards in any gear and powershift. Linkages all seem to be moving properly. Hydraulics have been really slow on the rear lately also. Any help would be appreciated since the last time he had a tractor at the dealer for PS problems it cost him more than the tractor originally cost him. SO taking it to our dealer is not an option.
Update***
Got it to go forward tonight by shifting it to PS2, but it seems to surge in PS2 but works fine in PS3 and PS1. Sometimes when I put it in reverse and back in PS1 it goes backwards until I shift to PS2 but not all the time. I'll probably pull the control box tomorrow and see what I can find. I did pull the small plugs ( 1 at a time) on the side of the control box and C1, C3 and C4 all had fluid flowing out while running but C2 did not.
Thanks for any help!!
John
(quoted from post at 16:30:20 09/01/14) Sounds much simpler than pulling the control box. Sounds like the cable is bad.
Nope, it was a stuck valve. All the cables and linkages are good. Pulled the control box and pulled each valve out and found C2 stuck, but not too bad. Cleaned everything real good, put it back together and walla, it works. For now anyway, I'll get it hooked up to the disc tomorrow and see how she does.
Thanks
