What model cases share a narrow front that will fit
on a 211b? Also if I understand this correctly that
a triple range goes about 25-28 mph down the road?
The early 300 and the 300b, 400b series and the 430 and 530 should be the same. The wide front on my 311b came to this place on a 530 and has been moved around till it ended on the 311b. The later ones of the 30 series may have been changed.
Barry is right. Any of the any dual front wheel pedestals from 300, 300B/400B, 430s, and early (before serial number 8199596, Mid 1962) 530s with 28" rear tires will fit on your 211B. Case used the same assembly on all of them.
The tractors from the same era with 36" rears had a dual front wheel pedestal assembly that was consistent with the 700B, 800B, 730, 830, 930Ck and 1030. Actually, I believe the same pedestal was used on the 770-1170s with narrow fronts.
The triple range tractors were definitely speedy.... High 20s were realistic, particularly those with higher rpm settings and 36" rubber. My 430 tops out at about 20 mph, but it has 28" tires and tops out at 1750 RPMs
If you need a new narrow front pedestal assembly, I have a rebuilt (bearings and seals) one.... Kansas City area... email is open
