CHUCK CAMBIS
I have the manuals, but don't tell what is needed
to remove rear cover WITH a cultivator lift
attached. can i just remove the cover bolts and
remove the whole mess including pto shaft or not.
can I re-install the same way or is there pto
coupling problems with the in and out lever
assembly. and lastly what happens to the trumpet
gaskets when you adjust the chain? THANKS FOR ANY
SUGGESTIONS!
SUGGESTIONS!
