Anonymous-0
this has got me perplexed ,, 4th one this yr. The 430 diesel killed the 1st one this spring ,i would swap a battery into it that has some age from something else ,, today it kilt the 4th one ,and I am wondering if the starter solenoid is causing it? ,,1st time it happened the battery was being overcharged by the delco remy alternater ,,overcharged so much it was about to explode , , got hot too ,,and would crank the tractor all the way home you would think ,, BUT was stone dead the next day. and it would not take a charge .. put battery 2 on the 430 and it was trouble free for ABOUT 30 DAYS ,then that battery was junk like the 1st ,,,my charger worx well on other batteries ok , guys ,,.battery 3 would not hold up over a week without needing charged . now I am thinkin the alternater has failed ,,didn't have time to run the alternater to shop . .so I swapped it to a better battery, ,,.and got along for a couple weeks .today the battery needed charged again , after 3 hours on the charger set on low ,. it began raining and hard , went out there after the rain, heard the starter solenoid cliking , never heard that before ,, and it was warm ,,the cables were warm , and so was the battery ,, btw ,, I most always charge my batteries from the starter solenoid ,,its easier than opening the battery hatch ...surely that is not the cause ??? maybe the alternater is now bad ,, and maybe the starter solenoid occasionally shorts out and grounds the battery out ,, I dunno ..gonna take both starter and solenoid , and alternater to the electric man and have him chek them out ...
