reddie
hi guys just picked up a little vac.. new to case tractors. just wondering if the belt pully is removable.. and if it has any value.. thank you
Yes, the belt pulley is removable. If it doesn't have the built-in hydraulic unit, then you just remove 4 bolts and pull it out. You will also want to drain the torque tube before you remove it or you will have a mess, and you will need to make a plate to cover the hole so that you can refill the torque tube with oil.
Yes the drive and driven gears are helical, it pulls right out. Drain the torque oil, unbolt it and pull straight out. You will need to put an oil tight delete cover with gasket on the opening.
I've seen guys fab a cover out of 1/4" flat stock. The original delete plate is casting nr VT-41. It is the same plate as on the 300/300B and some of the other number series tractors.
Joe
(quoted from post at 11:48:07 08/24/14) ok thanks... what do I use for oil to replace after I drain and remove unit?
whatever gear oil you put in the transmission
Oil depends on if you have a hydraulic pump mounted on the right front of the engine you need a low viscosity oil. General purpose hydraulic oil is suitable.
If no hydraulic pump use the same oil as in the transmission as already advised. Factory transmission lube was 90 wt gear oil.
Torque tube capacity is 2 gals.
Joe
so if I use like a 80w-90 will that be fine... also it looks like the fill spot is a small plug of left hand side of the torque tube... is this correct
ok thank you... next question my fuel cap is always loose... does anyone have a part number for one that I could get from lets say a carquest or napa...
The original cap p/n was G13271 changed to D93757. Carquest or Napa should be able to cross one of those nrs to a cap that will fit your tank filler neck. It probably will not be the original round dome type cap, more likely a universal cap with ears.
Joe
