case 430 hoe
hd6gtom
I think I have the number right. Son is looking at a older case hoe. He said it starts good the first time you start it, but if you run it a while and shut it off you have to really play with the throttle to get it to start again. Is this something sorta normal?
not normal no, sounds like it needs some carb work and that is normal for its age, 430CK/530CK great units even by todays standards good luck on the purchase
cnt
sounds like a weak coil to me, they get hot and break down then spark gets weak. try a new coil. for 12v sys it should be about 2.8-3.0 ohm resistance across + - terminals. add a ballast resistor if it is like 1.2 or 1.5. if it shows any continuity to the case from any terminal it is bad.
