TractorLinks.com
Show Parts for Model:
Re: Is it 6v or 12v??
Case Nutty 1660
08-20-2014 14:21:27
they were 6 volt pos ground from the factory, I have converted several of them to 12 volt, I just installed a resistor to cut back the volts to 6, hooked the wires correctly on the coil for Neg ground and installed a Alt
gtrscott
08-20-2014 14:31:07
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:21:27
Case Nutty 1660 said: (quoted from post at 14:21:27 08/20/14) they were 6 volt pos ground from the factory, I have converted several of them to 12 volt, I just installed a resistor to cut back the volts to 6, hooked the wires correctly on the coil for Neg ground and installed a Alt
Thanks, I do realize that originally they we 6v and many have been converted. I also inherited a restored VAC and it's 12v with an alternator.
The VA in question doesn't have an alternator though, so how can I verify which voltage it's currently wired for?
I'll also have to see if it's currently a positive ground, that'd be a dead give away.
This post was edited by gtrscott at 14:36:52 08/20/14.
Case Nutty 1660
08-20-2014 14:47:58
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:31:07
I use my volt meter if in doubt of voltage
gtrscott
08-20-2014 14:56:34
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:47:58
Not sure how the meter would help, if a 12v battery was put in by mistake, I'd see 12v in the system, right? It won't run so I can test the generator output. :?
Case Nutty 1660
08-20-2014 15:21:50
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:56:34
sorry thought you ment voltage going tot he points, the gen should have a tag that is stamped with voltage, if not a starter/alt repair shop should be able to tell from the insides what it is
gtrscott
08-20-2014 15:35:41
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 15:21:50
I'll take a look for the tag and go from there, thanks!!
OliverNate
08-20-2014 14:46:07
just because its positive ground doesn't mean its 6v, I had a 68 White 4000 semi and it was 12v positive ground.
Case Nutty 1660
08-20-2014 14:50:56
 Re: Is it 6v or 12v?? in reply to OliverNate, 08-20-2014 14:46:07
Nate, all Rock Island build tractors were "Pos" ground from the factory no matter if they were 6 or 12 volt, all Racine build tractors were "Neg" ground, just the way CASE did it then lol,
gtrscott
08-20-2014 14:59:50
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:50:56
Case Nutty 1660 said: (quoted from post at 15:50:56 08/20/14) Nate, all Rock Island build tractors were "Pos" ground from the factory no matter if they were 6 or 12 volt, all Racine build tractors were "Neg" ground, just the way CASE did it then lol,
Wow, they sure made easy...NOT!!! :lol:
Maybe I need to take of the generator and spin it on the bench to see what voltage I get.
This post was edited by gtrscott at 15:01:10 08/20/14.
C Kain
08-20-2014 20:36:35
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:59:50
well, a generator can put out either polarity, depending on the polarity it is initially 'excited' with. The tag on it is best information.
