TractorLinks.com
Show Parts for Model:
Is it 6v or 12v??
gtrscott
08-20-2014 10:43:45
Hi,
I've inherited a Case VA and I'm having ignition trouble.
The symptoms are: It would run for a moments then die. After a few tries it wouldn't start any more and there is no spark.
What I know: The top of the coil is cracked, top of condenser looks swollen and the points cooked and look like they've over heated (the end of the contact arm is discolored).
It has a 12v battery, but the way everything is so badly cooked. I'm thinking that it's probably still a 6v system, so before I start ordering parts, how can I verify what it's supposed to be and, if it is 6v, what else it likely cooked?
Thanks in advance!!
Scott
ss55
08-20-2014 16:25:22
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 10:43:45
If the tractor has lights, put out a light bulb and see which voltage the bulbs are.
gtrscott
08-20-2014 16:30:35
 Re: Is it 6v or 12v?? in reply to ss55, 08-20-2014 16:25:22
Great idea! Except the lights gone. Thanks!
Case Nutty 1660
08-20-2014 14:21:27
they were 6 volt pos ground from the factory, I have converted several of them to 12 volt, I just installed a resistor to cut back the volts to 6, hooked the wires correctly on the coil for Neg ground and installed a Alt
gtrscott
08-20-2014 14:31:07
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:21:27
Case Nutty 1660 said: (quoted from post at 14:21:27 08/20/14) they were 6 volt pos ground from the factory, I have converted several of them to 12 volt, I just installed a resistor to cut back the volts to 6, hooked the wires correctly on the coil for Neg ground and installed a Alt
Thanks, I do realize that originally they we 6v and many have been converted. I also inherited a restored VAC and it's 12v with an alternator.
The VA in question doesn't have an alternator though, so how can I verify which voltage it's currently wired for?
I'll also have to see if it's currently a positive ground, that'd be a dead give away.
This post was edited by gtrscott at 14:36:52 08/20/14.
Case Nutty 1660
08-20-2014 14:47:58
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:31:07
I use my volt meter if in doubt of voltage
gtrscott
08-20-2014 14:56:34
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:47:58
Not sure how the meter would help, if a 12v battery was put in by mistake, I'd see 12v in the system, right? It won't run so I can test the generator output. :?
Case Nutty 1660
08-20-2014 15:21:50
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:56:34
sorry thought you ment voltage going tot he points, the gen should have a tag that is stamped with voltage, if not a starter/alt repair shop should be able to tell from the insides what it is
gtrscott
08-20-2014 15:35:41
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 15:21:50
I'll take a look for the tag and go from there, thanks!!
OliverNate
08-20-2014 14:46:07
just because its positive ground doesn't mean its 6v, I had a 68 White 4000 semi and it was 12v positive ground.
Case Nutty 1660
08-20-2014 14:50:56
 Re: Is it 6v or 12v?? in reply to OliverNate, 08-20-2014 14:46:07
Nate, all Rock Island build tractors were "Pos" ground from the factory no matter if they were 6 or 12 volt, all Racine build tractors were "Neg" ground, just the way CASE did it then lol,
gtrscott
08-20-2014 14:59:50
 Re: Is it 6v or 12v?? in reply to Case Nutty 1660, 08-20-2014 14:50:56
Case Nutty 1660 said: (quoted from post at 15:50:56 08/20/14) Nate, all Rock Island build tractors were "Pos" ground from the factory no matter if they were 6 or 12 volt, all Racine build tractors were "Neg" ground, just the way CASE did it then lol,
Wow, they sure made easy...NOT!!! :lol:
Maybe I need to take of the generator and spin it on the bench to see what voltage I get.
This post was edited by gtrscott at 15:01:10 08/20/14.
C Kain
08-20-2014 20:36:35
 Re: Is it 6v or 12v?? in reply to gtrscott, 08-20-2014 14:59:50
well, a generator can put out either polarity, depending on the polarity it is initially 'excited' with. The tag on it is best information.
