220 Case lawn tractor
PatsySD
Here's my 1984 220 Case lawn tractor. I restored it 6 years ago. It has a sleeve hitch, and I have a plow and disc to go with the tractor.
Just curious whether or not you have ever used the plow. Was wondering if they work very well on those tractors. That is a very nice tractor!
I have used the plow only once, it was in some wheat stubble we had been plowing with the VAC, SC and DC. The ground was pretty hard and dry. I had a tough time getting it to go into the ground, plus it needs to be scoured. Had another lawn tractor friend tell me about a manual to help set the little Brinly plows up to work. Never have seen the manual or used the plow since. Disc works great, has a weight box mounted on it and I put a cinder block in there for weight. Used it to redo some grass a few years back.
