Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2294 trans again!
1370rod
08-19-2014 19:48:02
I bet you will more than likely find bad gears as Mel has mentioned. But before jumping to conclusions, I would pop the steering pump off the end of the pump stack and crank engine to see if the main pump shaft is turning. If it is not, pull the cover off the trans as Eric mentioned and inspect those gears. And they could be good, I have seen the splines in the flywheel that drive those gears worn out. If it is turning, then there is a issue with the charge pump. More than likely a sheared drive key in the gear. A non operating charge pump causes the loss of all hyd systems and noisy cavitating pumps also.
