Gitten The Wood Home
Adirondack case guy
Today was firewood day. Got way toooo much going on. Tomarrow I have to put back on my carpenters hat with pencil stuck under my ear.
Loaded and brought home two loads of fire wood today with the dump trailer and 440, and one on the dodge PU a couple days ago.
Loren
Loren,
Great looking 430 and trailer .. by the way is the axle { what I call a "walking axle" } doesn't have any springs on axle ..??
I'm redoing my homemade dump trailer... and that's what I'm putting under mine .. running wires for the brakes , makes me scratch my head a lot ...lol
...... mark
Geez Loren you even do a neat job of stacking the wood in the trailer also, and the pieces are so uniform. Some day I got to get out there so you can teach me the correct way of putting up firewood. Rod.
I can see from the pics and earlier posts that You tend to get things done in a timely fashion and may I also say I have been cutting firewood for the neighbors for about fifteen years and I do not think any one of my stacks were ever as neatly stacked as yours on the trailer. All I can say is great job and I tip my glass to You.
I will bet that Ram was ready to get that load off its back. Did you finally let that "Gotta Mechanic Comin'" retire??
Bryce
Bro,
It wasn't the night befor last and either was I. The shifting lever slid past and it locked into reverse again. Had to wiggle and twist the shift cover off, and get everything back into place. As you know, when the rail is protruding into the range housing, it is a tussel to get the cover moved back and off.
Loren
Rod,
I made simple length guides out of pex tubeing, and clamp them to the handle. It's flexible and returns to shape after bending.
Loren
The Rail Goes to Far when you put it in Reverse =Weld a peace or Steel or bolt to the Fork so it hits the Cover & will not let it go pasted the Detent [when it goes to far The Spring loaded part on the fork Pushes the Shifter out of the way at just the right time.we had a 530 Diesel that kept doing that,what a pain,once we fixed it never had any more truble.
