vac-14 hydraulics working thanks
i just want to say thanks to all you fine people for helping with the hydraulics on my vac eagle hitche found the spring for the check valve was rusted and not seating lol i went on and replaced all thebearings and the one spring found all at the local bolt supply house now to correct the lift operater control handle seams to not be in the right locatoin the lift arms go up darn fast sweet now i have a question i might have ask this be fore but weight wise how much will it lift as to me not over doing it
It will lift a 600lb eagle hitch plow and a 1000lb eagle hitch disk. Don't worry about over doing it, it will blow the pressure relief valve before doing damage (as long as you got the right spring). Also, don't try to fight the pressure relief valve. If it struggles to lift, then don't do it.
thanks now i will have to find some equipment shredder and plows exct.around central texas the old girl runs great front tires are dry back sheet metal is good needs some paint gonna use it around the farm about 38 acres
