Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Case 400 Hydraulic Fluid Level
JoeMohan
08-17-2014 12:36:26
Mechanically Inclined but knowledge impaired. How do I check the Hydraulic fluid in my 1956 Case 410. Under the seat it appears there is a breather. It looks like someone added a tee and an elbow to be able to leave the breather in place while filling. Is this indeed the filler? Is there a fill level plug or do I fill all the way to the top?
oldproudvet
08-18-2014 06:50:24
 Re: Case 400 Hydraulic Fluid Level in reply to JoeMohan, 08-17-2014 12:36:26
This may help. Use your mouse to enlarge
JoeMohan
08-17-2014 20:42:15
Bottom right? Is this on the side of the tractor or the back? Can you describe the location better? I may have to clean up the grass and grease around the pto to find it if it's in the back.
tomturkey
08-17-2014 13:07:05
You may fill it at the breather plug as you mention or on the bottom right (as you sit on the tractor) you will see a 3/4 inch plug you could fill there. The quarter inch plug below the 3/4 inch plug is the level checker plug.Hope I have not confused you. gobble
