Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
vac-14 hydraulics working thanks
will in texas
08-17-2014 08:17:18
i just want to say thanks to all you fine people for helping with the hydraulics on my vac eagle hitche found the spring for the check valve was rusted and not seating lol i went on and replaced all thebearings and the one spring found all at the local bolt supply house now to correct the lift operater control handle seams to not be in the right locatoin the lift arms go up darn fast sweet now i have a question i might have ask this be fore but weight wise how much will it lift as to me not over doing it
will in texas
08-18-2014 07:24:27
 Re: vac-14 hydraulics working thanks in reply to will in texas, 08-17-2014 08:17:18
thanks now i will have to find some equipment shredder and plows exct.around central texas the old girl runs great front tires are dry back sheet metal is good needs some paint gonna use it around the farm about 38 acres
Christopher Mikesell
08-17-2014 10:46:17
It will lift a 600lb eagle hitch plow and a 1000lb eagle hitch disk. Don't worry about over doing it, it will blow the pressure relief valve before doing damage (as long as you got the right spring). Also, don't try to fight the pressure relief valve. If it struggles to lift, then don't do it.
