Looking for a good Cummins mechanic
DKase
The 855 Big Cam 1 in my road tractor has me pulling out my hair. It is loosing about one gallon of antifreeze to 500 miles. No external leaks, no antifreeze in the oil, no compression in the radiator, no vapor from the breather or grey snot in the valve covers. I pressurized the after cooler to 15# and after 2 days no drips or signs at all in the intake. Pressurized the engine to 10# and no leaks after 3 days. Spin it with the starter with both manifolds off and no signs of any moisture. I plan to warm it up with both manifolds off today and see what happens. About all that is left is an injector cup. Any other thoughts?
Check the intercooler on the engine. It's a mini rad that can go bad and put anti freeze directly into the intake . Had one do it until one morning it totally failed hydro locking the engine.
As I posted, I pressurized the intercooler to 15# for 2 days, and pressure held. Pulled the intake, and there are no signs of antifreeze in the intake. That is NOT the problem.
I recall a new 5.9 that was losing coolant without a trace. Turned out the block was cracked(improperly cast) behind the exhaust manifold, and was only leaking when working hard, and the coolant sprayed onto the manifold and evaporated.
I had an engine here that was losing just a little coolant undetected, and finally when the water pump gave out and I replaced it, the leak stopped!
So I'm wondering if you have some similar oddity, where you can't duplicate the leak in a static condition?
An injector cup leak would allow compression into the rad. Does the rad have an expansion tank? If not, is the 1 gallon loss just normal expansion?
13 speed, no cooler. I have thought about the air compressor also. No antifreeze in the tanks, and no air dryer. No the heater core is not leaking. I think I pull the heads tomorrow and get them pressure tested, or replaced.
Take the belt off the water pump, pressurize the radiator to 15psi, turn and wiggle water pump by hand. Maybe it is loose and seeping.
Put some water soluable flouresant dye in the coolant, run it and get out the black light at night. It'll show up somewhere.
I know the antifreeze is going out the exhaust. I need to know how it is getting there without getting in the oil, or compression getting in the radiator!
I just had a JD mower with Kawasaki motor that had me pulling my hair out as well. Ended up being water pump that was seeping SLOW amount. Would only do it when running and was evaporating it as it leaked. As soon as I took water pump apart it was definitely evident. Fixed now. Don't know if this will be the same but just what I encountered.
