Case VAC-13 Plowing
connor9988
Location
Central Iowa
A couple videos of my VAC Plowing.
<iframe width="420" height="315" src="//www.youtube.com/embed/anNO0acZYs4" frameborder="0" allowfullscreen></iframe>
<iframe width="420" height="315" src="//www.youtube.com/embed/PgBm_X9T23g" frameborder="0" allowfullscreen></iframe>
Nick, it does have one set mounted on the inside of the hubs. However like most of the old ads I"ve seen with a vac plowing I think a second set on the outside of the hub would be a good thing.
I have two sets of weights mounted on my VAC-14, and the tractor's weight is either just right or a little too much depending on ground conditions and plowing speed. However, I am using an eagle hitch plow which weighs around 600 lbs., and I estimate that more than half of that is carried by the tractor. Thus, I would think that an extra set of weights would do you some good. I also have a set of front weights installed, but they are not necessary for plowing. I only need them to counterbalance raised three point implements.
