i have a case 1175--i used a disc the other day. It raised and lowered like it should although toward the end i was thinking it was getting slow and also i didnt fold the "wings" of the disc up/down etc...just raised it and lowered it as a whole. Today i go to use it, folded it up, raised it up and on my way. About 100 yds away the disc lowered down and will only make a weak attempt to be raised....yet using the same lever it seems to activate two separate cylinders to some degree. While lowerering(maybe raising i forget) the wings will try to lower a little bit as well....all while using one lever.---can someone explain to me whats going on? If its the hydraulic remote can it be rebuilt?
