ACEd
Can anyone tell me what a 1949 DC4 without any additional weights and no fluid in tires should weigh - possibly Original "Shipping Weight"
Mine's a 52 and weighs 5450 w/o weights.It's the longer wheel base with the solid cast front wheels.Ron
Thanks to both for quick responses - that confirms my hopes - closer to 5000 than 7000 pounds. I'm headed up to pick up tractor later this week and maybe a pair of smaller narrow front tractors and was concerned when I saw 7000 pounds on original Nebraska test. Looks like max load would be about 12,000-12,500 pounds on a dual tandem gooseneck that weighs about 7500 pounds empty. Right at 20,000 total which is about as much as I want to pull with F250.
Best, Ed
Longer Wheelbase - OK you have peaked my curiosity - I'm not that much of a Case person - 2 SC's, and a couple of VAS and VAH til now.
What I have is tagged DC, but it has wide non-adjustable front and 38 inch rear tires. I believe that is a DC4 based on pictures in Case books, but front wheels are under nose - not out front like the adjustable wide fronts. Front wheels are clamp on dismountable rims not cast.
So do I have a DC4 or am I misidentifying it? I know there were changes in brakes and hand clutch location over the years - did wheelbase of DC4 change? Were there multiple versions of DC4?
trying to post picture
What you have is an earlier model DC4. In 1952 you could add an Eagle Hitch 3 point setup, and that came with a big cast iron "heart" that extended the front axle, and cast iron tire rims that added significant weight way out front to offset mounted implements on the back. Don
