Case 1410 spin out wheels...
I have a Case 1410 that has a bad wheel. The valve stem leaked out calcium and it rotted the rim. It has 18.4x34 tires on spin out wheels with 7 rails. I believe the wheel size would be 16x34 for these tires, correct? I have been looking far and wide for these wheels, but can only find 6 and 8 rail wheels in this size (16x34). Is there a place I can find the 7 rail wheels for this tractor? Or is the center hub pattern for these 1410's the same as other case models with 6 rail wheels? I thought maybe if I found a compatible hub center for a 6 rail wheel, i could just change it to a 6 rail. Any help would be appreciated. Thanks!
