Case LA Clutch Brake Brake repair
dmat58
How much time and labor are involved to replace a clutch brake and the rear brakes on a case LA? Do you have to split the tractor or is it easier than that? I have looked on line for info on how to do it however, I have had no luck finding any info. Can anyone help? Thanks in advance for your help.
Clutch brake is simple; just renew the lining on the pulley brake.
The rear brakes depend on which one of several types you have. The ones on the differential shaft are easy; just renew the lining or replace the disks; I believe John Saeli sells them.
The other types require that you remove the hub from the axle as the brakes are inside the hubs.
