Brake work on DC 4
LME
Need to do some work on the brakes, never worked on them before. What kind of trouble am I going to find? They work, but not as good as they should. Thanks
Not hard to fix. If the seals aren't leaking oil you can usually clean , sand the glaze off the linings and use heavy grease on the balls and the brakes will work good. Late model brakes are different from early but both are simple. Nick
