Rod bearing info
Anonymous-0
I am working on a big crank 504 and the rod measures 3.00 inches but the crank says its 10 under so I'm trying to find out if the bearing I have is a 10 over. Part # on bearing is A41880. I have checked the parts in YT and at the dealer web site and I can not find this # does anyone have any ideas or know what that # is ? Thanks for any assistance.
My p/n exchange catalog (dtd 1989)lists p/n A41880 as used within kit p/n A41900.
Part nr search for A41900 partstore.caseih.com as follows:
BEARINGS, ENGINE - INTERNAL SET, CONN ROD BRGS (STD) SET, CONN ROD BRGS (STD) SKU: A41900.
Appears to be a standard set but I would use that order/inquire box to check with Case as my catalog is pretty old and things change often at Case, especially p/n's.
Joe
Every over sized bearing I have ever seen is stamped .010, .020 right by the part number.
Yup, that's the way it been in the past but now that much of the manufacturing has been outsourced to the Land of Almost Right, don't count on it.
Joe
