vac -14 eagle hitch
i have a 1953 vac-14 wide front with the eagle hitch on the pressure releif side valve the litle ball bearing what size is it the i-t manual does not have the size of it i lost mine and need to get one was taking it apart to see why it will not stay in the up position when i had a blade on it i am goig to replace the o- rings in the piston also
The check ball is 1/2" diameter and the spring OD is 5/8". I have them in my pocket, I'll try and get them sent on my way to Florida later this week.
