I have an Case 430 with a front loader and 3pt hitch. The hydraulics are strong when I first begin to use them. After a few minutes they slow down and eventually stop all together. When I shut the tractor off and immediately restart it they will work again for a short time.
I have already checked the filter and it is new & clean. Also the pick up tube has no screen on it so I know it's not plugged. I'm having trouble diagnosing it because I'm not sure I understand how the flow on this system works. Can anyone give me a short description on the flow?
Is there a lift pump and a High pressure hydraulic pump? Does it continuously make high pressure or only when I am trying to lift? Does it return all the fluid back to the res or is it a closed loop? Where is the fluid being filtered? Before of after the pump?
Thanks for any help!
