1370 Hydraulics Falling, 3 pt and Remote
Barry75
Need some help please. One of my 1370s has a hydraulic issue, both the 3 point and remotes will leak down while tractor is running. The 3 pt will drop, then pump up, then drop, then pump up. The faster the load, the faster the cycling. I assume seals are out of the primary pump since remotes are doing the same? Any advice on where/how to dig into this is much appreciated.
