Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2390 hydraulic remote
jrross
07-29-2014 08:00:59
Is the detent valve the large cylinder on the lower part of the valve with the larger nut and setting or the smaller one? I removed the small one from the #2 valve yesterday but did not remove the same piece from #1. The small one is only a needle valve with small spring. I can handle removing this. The larger one that is on the main spool is a lot more complicated isn't it?
dwag
07-29-2014 10:44:19
 Re: 2390 hydraulic remote in reply to jrross, 07-29-2014 08:00:59
My bad. Primary shuttle valve is under detent hsg and will affect the remote valve that contains it. Secondary shuttle valve is at back of valve body (A47204) and will have a screw head or allen head for removal. Bad secondary shuttle valve will affect remotes down stream.
Copyright © 1997-2015 Yesterday's Tractor Co.
