TractorLinks.com
Show Parts for Model:
Hard starting 830CK
oldproudvet
07-25-2014 18:40:28
Gentlemen: I recently picked up a '65 830CK 8spd. It takes a minimum of 30 seconds w/the glow plug to get it to fire. My 2 400s and my 1070 pop with the key, down into the 20s. I'm not familiar with the Bosch in line pump as of yet. Worked with the single piston rotary for years, they're awesome. Any thoughts? I've yet to locate the proper shop manual. Thanks
millerimplement
07-26-2014 14:01:47
 Re: Hard starting 830CK in reply to oldproudvet, 07-25-2014 18:40:28
Do not grind the valve seats back in to the heads!!!!!!! Put in new seats and new valves if they are thin!!! At higher elevations raise the ex seat a little. That area IS THE COMBUSTION chamber on a powercell engine.
pete 23
07-26-2014 11:34:06
Case issued a service bulletin in regards to hard starting after overhaul. I don't remember exactly which engine it addressed but sounds like this model. It gave detailed piston protrusion, connecting rod center to center dimensions and valve recessions as I remember. I know I gave a copy to the local machinist for his reference but I don't know if I have a copy anymore or not. At any rate, it was one particular line of their engines that was giving the problem and I believe it was energy cell injected, not the direct injection open chamber engines.
Brokengun
07-26-2014 09:14:07
I have heard of 830CK diesels that were over-hauled using thin wall sleeve sets that were hard to start.
Do you have blow by or excessive smoke when you first start the tractor?
What about a little miss-fire from an injector when it first starts?
tractor300
07-25-2014 20:33:58
That's just kind of the nature of a 30 series. I have never saw one that started good cold with out some help. Warmed up they start fine, good old tractors.
John Saeli
07-26-2014 05:03:03
 Re: Hard starting 830CK in reply to tractor300, 07-25-2014 20:33:58
Not so. With 2 premium 12V batteries hooked in parallel, good cables, any 30 series should start without aid down to 45F. Our 800 & 730CK will both start down to 35F - 40F without the glow plug. Often times, hard start comes after pounded valves & seats & a poor valve job. I cringe when I hear someone say they had the "valves ground" on a diesel, especially a CASE.
DKase
07-26-2014 09:05:20
 Re: Hard starting 830CK in reply to John Saeli, 07-26-2014 05:03:03
The 830 and 1030 always started much harder than the 730 and 930. An 830 in tip top shape will start like a 730 that is 3/4 shot.
Case Nutty 1660
07-26-2014 12:20:33
 Re: Hard starting 830CK in reply to DKase, 07-26-2014 09:05:20
wonder why that is? I agree with you completely
cnt
DKase
07-26-2014 14:38:30
 Re: Hard starting 830CK in reply to Case Nutty 1660, 07-26-2014 12:20:33
I wonder if the compression is just a little less . It would be interesting to CC them and figure it out. If I ever have 830 heads off for valve job I will try to install thicker seats under the valves that are up in the hole in the head. I have done that on 930's and it has made a huge difference. The 830's are like the energizer bunnys, I have never had one apart.
JW
07-26-2014 18:38:54
 Re: Hard starting 830CK in reply to DKase, 07-26-2014 14:38:30
What do you use for thicker seats? I like that idea
DKase
07-26-2014 19:58:20
 Re: Hard starting 830CK in reply to JW, 07-26-2014 18:38:54
The machine shop that works on my heads simply installed a thicker seat. The outside diameter that sticks out of the head needs to be ground to a radius rather than square so it will not get hot. DO NOT do this on the valve that is flush with the head or it will hit the piston!
Case Nutty 1660
07-26-2014 06:03:11
said this before John, they did not do that new here at our elevation, maybe where you are they do/did but not here, if Larry's 830 starts with the glow plugs that easy he is golden to me, I would not worry a bit about it
cnt
jon f mn
07-26-2014 10:27:07
 Re: Hard starting 830CK in reply to Case Nutty 1660, 07-26-2014 06:03:11
My thoughts too Tom, sounds like it's good to me.
cshess
07-25-2014 19:44:01
I would first check timing of injection pump That is easiest to do.Providing the pointer at fly wheel is corectly set an not bent turn crankshaft till you find the 29tdc mark on fan pulley.Than remove big cap nut directly in front of injection pump an if you are lucky an are on firing time marks of cylinder no 1 there should be a scribe mark on pump flange an one on gear lined up.if no line to be seen you will have to turn engine one full revolution as you were on no 4 cylinder.Scribe marks are very faint an you need to clean an look closely to see them.If they are close but not in line loosen injection pump an line them up.If that is not problem do as John said.
oldproudvet
07-25-2014 19:32:04
I should have elaborated. This is a COLD start only issue, warm it starts immediately and runs out like a watch. I've used it to cut around 140 acres of grass hay so far, very happy with it and quite an upgrade from my 400s. John, I will flow the injectors this winter, I've got the Bosch test eqpt. It runs so well it's not worth tinkering with now. No blowby, no oil consumption issues in the hours I've used it. Thanks
John Saeli
07-25-2014 19:04:29
First thing to do is have the injectors checked, & while they are out, do a compression check.
John LaBoyteaux
07-25-2014 19:04:13
My 830 and 1030CKs always start more easily at half throttle, even without the glow plug.
