Anonymous-0
Have an early 70's 580 CK that sat for some time. Got it running again, however, will not move when I put it gear. HOWEVER, when I engage the stablizers and put it up in the air, the rear tires will turn both forward and backwards when in gear.
When I put it back on the ground, it will not move!!!!
Main thing I notice is that when I turn it on, it begins to leak oil fluid from behind the starter area. It leaks quiet a bit so I know it loses pressure and does not allow it to move.
Question:
- Is there an o-ring or seal somewhere around the starter area where the leak is?? Or is it something "deep" internal which requires splitting?? (Don't look forward to this part).
Thank you in advance for your advise and assistance. David
Question:
