LA Case question
Circle K
Hello, I was recently approached by a neighbor about purchasing a LA Case tractor. I am not real familiar with Case tractors. The motor is loose and the owner is pretty confident it will run with some fresh gas and a pull. My question is, are parts pretty hard to find for these if I would need anything for it if I did restore it? Also, might be kinda a dumb question, but does anybody know how fast the LA will go? Reason I ask is because I would like to participate in a couple tractor rides with it. Any help appreciated. Thank you
Parts can be found. Speed depends on the gearing. My 45 LAI is a four speed and in fourth gear it is supposed to run 10 mph.
