case 530 remote hydarulics
yes they were a option, the remote levers if equipped are beside the Draft-O-Matic lever or if a early one by the Eagle Hitch lever
Thank you case nutty is the draft o matic the lever tat raises and lowers the 3pt hitch if so the 2 levers next to that move the loader and bucket
yes here is a pic of my 430, levers are bent different but the same control
cnt
cnt
I guess you need to let me know what you really have, maybe a 530CK? in any case if it has its own pump that will have its own valve to operate the loader, if your tractor has factory remotes and 3pt that is a separate system from the front pump loader system
Its not the ck version the remotes are seperate from the loader pump as far as i know I guess I have some tracing to do tomorrow and the loader is a 380 if that helps thanks again
